11-07-2017
03:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-07-2017
03:15 AM
If you set the text position horizontal and vertical to centered you should get the result you want.
For some reason however your 'text inside align' property in your drawing defaults to 'On', which causes the text to offset for some strange reason. If you switch that property to Off your text will align properly. (see screenshot)
I don't know which variable controls that setting though, nor do I know how you can enforce that setting through the DIMSTYLE. Maybe someone smarter than me can help you out with that.
