11-07-2017
03:11 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-07-2017
03:11 AM
go into your Dimstyle dialogue box set current the dimstyle you will be using
go to the text tab and select centered for both vertical nad horizontal, then check Aligned with dimension line.
if you need the text to be above the dimension line set the vertical to above
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
