4168 Vistas, 9 Respuestas
Dimension Text - Vertically centering
I have problem with dimensions centering position.
I have problem to prepare Dimension stile in the way to put the dimension to the center (horizontal and vertikal). Horizontal no problem but when I choose the "centered" commend for horizontal than the program throws the text higher instead to the center.
Before when I worked with AM_DIN dimension stiles I had no problem. Now I am preparing the "TEMPLATE" DWG neu and make neu stiles I have a problem.
Thanks for help.
Boris
imadHabash
en respuesta a: Anonymous
i,
when i use your dimension style (Transpak text 05 ) i have not notice your issue. try to use from Dimension tab >> Linear option . and don't forget to set current your needed dimension style. if do you want to move the text select the dimension and hoover over the middle grip till a pop up appeared with some options that may help. see below image
Imad Habash
en respuesta a: imadHabash
I need the dimension in this way. When I select the "Center" vor vertikal position it goes hier instead to center between the Dim lines.
kadmonkee
go into your Dimstyle dialogue box set current the dimstyle you will be using
go to the text tab and select centered for both vertical nad horizontal, then check Aligned with dimension line.
if you need the text to be above the dimension line set the vertical to above
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
imadHabash
set current your needed dim style then change DIMTAD and DIMTVP to (zero) . see below image
Imad Habash
Michiel.Valcke
If you set the text position horizontal and vertical to centered you should get the result you want.
For some reason however your 'text inside align' property in your drawing defaults to 'On', which causes the text to offset for some strange reason. If you switch that property to Off your text will align properly. (see screenshot)
I don't know which variable controls that setting though, nor do I know how you can enforce that setting through the DIMSTYLE. Maybe someone smarter than me can help you out with that.
en respuesta a: kadmonkee
Look at the DWG I uploaded. If you do the settings you described happens what I described.
Kent1Cooper
DIMTAD was already zero in the example drawing, but DIMTVP was not.  Setting that to zero fixed it for me.  The odd thing is that I have not been able to find anything in Help about where that is  in the Dimension Style dialog boxes, if anywhere -- it seems you just need to know about the System Variable.
Kent Cooper, AIA
imadHabash
en respuesta a: Kent1Cooper
Imad Habash
Kent1Cooper
@imadHabash wrote:
I'm sure I got that 0 from somewhere, but now I don't know what I was looking at....  But while it's 3 in the drawing at large as you open it, if you set the Style of the drawn Dimension current  with no overrides, it's [still not 0, but not 3 either] 1.
Then, drawing another Dimension in that Style doesn't have that big offset in text position, because that's caused by DIMTVP, which applies only when DIMTAD = 0.  It's 1 in the definition of that Style, but that drawn Dimension has six  overrides in Extended Data, of which presumably one is that DIMTAD is 0 instead of the Style's 1 [I think it's the  (1070 . 77) (1070 . 0)  pairing in Xdata].  That would have caused the drawing's  DIMTVP value of 2.5 to affect that Dimension.
DIMTVP as a numerical value doesn't seem to appear in the Properties palette -- just the resultant  displaced text position.
TO FIX that displaced-text one, in Acad2016 or later, you can use -DIMSTYLE > Apply, or in earlier versions, DIM > Update.
Kent Cooper, AIA
