Vinayv4v
en respuesta a: Anonymous
@How do I set my line thickness to 0 for the rectang function?
Since you are using a rectangle function, type the command REC and check the following
REC > T (Thickness) > If it is set to <0>
(Thickness is seen if you are in 3d)
REC > W (Width) > If it is set to <0>
This will change the global width of the rectangle according to given value.
Cheers,
Vinay Vijayakumaran
