Kent1Cooper
en respuesta a: Anonymous
I'll add another possibility to @Anonymous's -- THICKNESS or WIDTH or LINEWEIGHT?  Those are three  different things.
RECTANG makes them at zero width even when PLINEWID is non-zero [at least up to and including Acad2016 that I'm running here], so I don't think that can be it [unless you don't really mean  "the rectang function," but are drawing them with the PLINE command].  But if you have a lineweight  assigned to Layer 0, or in the current-entity properties, and you have it set to show lineweights, you'll see that.
Kent Cooper, AIA
