- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a drawing that when I draw a PLINE, it only displays the segment after both the start and end of the segments have been defined (displays after 2 clicks). In my template and with all new drawings, when I run the PLINE command, I click once to start the PLINE and then the preview follows my cursor until a 2nd point is clicked - this is the behavior I want in the first drawing. I seem to remember there is a drawing variable that controls this behavior, but I cant remember that variable name. Help! Thanks...
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
DRAGMODE? it could possibly be what you are looking for. but that does not appear to be a per drawing setting.
can you record a screencast of what it is doing that you want, and what it is doing that you dont want?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Great idea about posting a video. In the first half, you see the 'flawed' behavior where I cannot see the segment of the PLINE that is about to be drawn (if i click the next point). In the second half of the video you see the 'normal' behavior where I can see the segment that will be created if I click a point.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
that definitely looks like DRAGMODE, as you can see here:
It will take a bit for the video to finish processing:
https://knowledge.autodesk.com/community/screencast/a79d15c6-1634-4dc4-ba00-7dd24168b79a
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There was corruption in the dwg, and after AUDIT Y, then saving and close/reopen, now the DRAGMODE variable controls that behavior.
Cheers!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
it turns out the PLINE width also needs to be 0. as soon as the width is non-0, the 'about to be drawn' segment no longer follows the cursor and it only appears after the point has been clicked.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks - that's what I needed/
Autodesk Certified Professional
http://designandmotion.net
