imadHabash
en respuesta a: Anonymous
>> I just don't know how I can intersect the lines with each other? <<
i suggest to use TRIM command . select first the lines then select the area or the space that you don't need. also i see from your image that there is another small lines existing at the end of plus sign that maybe need ERASE command .
Imad Habash
