932 Vistas, 7 Respuestas
Text Height in properties
How do you change a single text height when the text height doesn't show to the properties list?
ennujozlagam
en respuesta a: Anonymous
@Anonymous hello, select the text > right click > properties, please see attached. thanks
en respuesta a: ennujozlagam
Thanks for the reply, but the Text Box is not showing in the Properties palette. How do I bring that up?
ennujozlagam
@Anonymous hello, try in the command promp type MO. thanks
ennujozlagam
@Anonymoushello, if still doesn't works, try to install latest updates, service packs and hot fixes from autodesk and see if helps. thanks
alternatively you can refer to this LINK.
Alfred.NESWADBA
Can you please show us a screenshot what you see in the properties window when you have selected  thar entity?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Hi and Welcome to AutoCAD Forum,
>> ...but the Text Box is not showing in the Properties palette. How do I bring that up? <<
make sure that you select only the text and without any other object.then type Ctrl+1 while selecting text object . a properties dialog will appear go for text pane and check if it's expanded well form the ( - / + ) symbol and as shown in the below image.
Imad Habash
HI
go to text style dialog box (ST).
Create new style with required height.
then come to model space and select text.
then press ctrl+1 for properties
now change style to new style from text section
you can also apply bold, italic and bold italic for text from text style dialog box
Etiquetas (1)
