Alfred.NESWADBA
en respuesta a: Anonymous
as long as the DWG-file is connected to "AutoCAD Dwg Launcher" a double click to a DWG-file will start that type and version and profile of AutoCAD you had started the last time.
>> when I click on any .dwg file it will open AutoCAD 2017 but I need 2018 open
AutoCAD does not know what you want in that moment. How should it :cara_guiñando_un_ojo:
My workflow in such cases is to open that type/version/profile of AutoCAD I need and then double-click or drag&drop the DWG-file into AutoCAD.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
