en respuesta a: Haider_of_Sweden
if you have solid object. then use "SLICE" command to split your object. it will allow to separate from cutting plane.
pls follow command information :-
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
