10-22-2017
01:11 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-22-2017
01:11 PM
>> I'm trying to put annotation on my cylinder which is 40 in length the
>> annotation doesn't go with the height, it goes on the ground
You can create dimensions only in the current UCS, so if you need a vertical dimension, then create an UCS that defines a vertical plane for your dimensions.
>> I don't know how to make areas marked in red
Create BOX and then one time command _UNION (for the lower missing object) and one time command _SUBTRACT for the upper (horizontal) box.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
