- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello everyone,
I'm newbie with autocad and Ive just started 3d drawing and I need some help with my project. As you can see in the photos, I don't know how to make areas marked in red, you can see my progress in the first drawing. And I have problems making annotations - like when I'm trying to put annotation on my cylinder which is 40 in length the annotation doesn't go with the height, it goes on the ground and doesn't attach to the cylinder like it does in the photo. Also I would like to know if my progress which Ive done is right and if I'm making my drawing correct according to the example. Thank You.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> I have problems making annotations <<
if you're working by isometric dwg then i suggest to follow this great link tutorial to help you. >> Click <<
>> Also I would like to know if my progress which Ive done is right .... <<
till now it's cool but still need more ... let us see it after you finish it to give you final comments.
All the best..
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can create dimensions only in the current UCS, so if you need a vertical dimension, then create an UCS that defines a vertical plane for your dimensions.
Create BOX and then one time command _UNION (for the lower missing object) and one time command _SUBTRACT for the upper (horizontal) box.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI,
>> Hey guys, I made some progress, what do you think? Does everything seem to be ok? <<
Cool ... it looks neat . good job.
all the best.
Imad Habash
