imadHabash
en respuesta a: Anonymous
you can deal with dwg files depending on file format that you use. each AutoCAD-based product uses a specific file format when saving to a file, which is important when sharing files. The following table outlines which file format should be used when sharing files with other users of AutoCAD or AutoCAD-based products:
File Format AutoCAD Release
AutoCAD 2018 AutoCAD 2018
AutoCAD 2013 AutoCAD 2013 - AutoCAD 2017
AutoCAD 2010 AutoCAD 2010 - AutoCAD 2012
AutoCAD 2007 AutoCAD 2007 - AutoCAD 2009
AutoCAD 2004 AutoCAD 2004 - AutoCAD 2006
AutoCAD 2000 AutoCAD 2000 - AutoCAD 2002
AutoCAD R14 AutoCAD R14
AutoCAD R12 DXF AutoCAD R12
Imad Habash
