359 Vistas, 3 Respuestas
Line Weight In Dims
So I'm working on files that I did not create and the 1st file I worked on the dims were fine but this 2nd file I have discovered that the dim lines are showing a width.
I've checked all of the normal locations and I can not find what is generating the width!
The layer is set to Linetype: Continuous and Lineweight: Default
I've checked the properties and they all read as bylayer for both settings.
Dim style shows everything also set to bylayer.
If it helps the text style is Standard and the font is Arial, Regular.
I've used dims at these setting before so I'm not seeing anything out of the ordinary.
Does someone have an idea on what I may be missing?
It might be something simple that I'm totally overlooking.
Just so you know it doesn't appear to be affecting the lines on the printed sheets but it still bugs me and I'd like to be able to fix it.
Thank you for looking,
Radar
