Johanna_Esteban
en respuesta a: Baz_man
Hello Barry,
If each element is in its layer, and "bylayer", each layer with its thickness, type of line the detail must be here: (See image)
The icon activates or deactivates the thickness display, without printing, but the very small thicknesses do not differ, so if you want to be sure you could print a part in pdf. If it is still not possible to adjust it, could you attach the file to help you?
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! :cara_guiñando_un_ojo:
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
