Alfred.NESWADBA
en respuesta a: Anonymous
>> got of 1000 dwgs to make a change
Wouldn't be the faster option to place your property window in a free space on any of your monitors, select the block-insertion (or multiple) and edit the values in the property window.
Advantages ... you don't need to start a command, + you can edit multiple block-insertions in one step if they should get the same attributes filled with the same value.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
