Alfred.NESWADBA
en respuesta a: Anonymous
>> I need the rectangles to go down about half way
Command _PRESSPULL could help for that.
>> everything else needs to be completely hollow
You can always use command _SUBTRACT to create a new 3D-Solid based on 2 solids, one solid is the base and other solid is subtracted from the first.
>> From what I can tell, all I have to do is extrude?
As the first step you can do that, but then you need to combine the objects, e.g. the cylinder as the outer object and subtract the inner extruded circles to make holes in the outer object.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
