10-11-2017
12:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-11-2017
12:35 AM
HI,
i suggest to use Project (view) option from trim command . it will works as seen from below image.
Command: tr TRIM
Current settings: Projection=View, Edge=Extend
Select cutting edges ...
Select objects or <select all>: 1 found
Select objects:
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase/Undo]:
Does not intersect with the cutting edge.
[Fence/Crossing/Project/Edge/eRase/Undo]: p
Enter a projection option [None/Ucs/View] <View>: v
Imad Habash
