koseku3
1610 Vistas, 2 Respuestas
Trimming an arc in 3D
 Hello people,
I'm trying to trim an arc with a line cuttşng edge in a 3D but somehow i cannot. At first picture, you can see the plan view and UCS is world. I type trim, selects the line, enter, select the part of the arc to be trimmed; but nothing happens. At second picture, you may see they actualy dont intersect.
When i try a line instead of arc, it works, but somehow, it doesnt work for arcs.
Also when i try to change UCS randomly, it trims but not as i want.
So this has to be something about UCS. How do you find the best UCS for trimming an arc?
Etiquetas (1)
imadHabash
en respuesta a: koseku3
HI,
i suggest to use Project (view) option from trim command . it will works as seen from below image.
Command: tr TRIM
Current settings: Projection=View, Edge=Extend
Select cutting edges ...
Select objects or <select all>: 1 found
Select objects:
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase/Undo]:
Does not intersect with the cutting edge.
[Fence/Crossing/Project/Edge/eRase/Undo]: p
Enter a projection option [None/Ucs/View] <View>: v
Imad Habash
koseku3
en respuesta a: imadHabash
Thank you!
