252 Vistas, 4 Respuestas
Start menu not opening the correct file
on the recently opened files, I go to select a file and my cursor is on the four file down but it highlights the file that is three files above it.   When I go to open the file it open the one in the list that is three or four above the one I click on.
Thank you!
Rob
Alfred.NESWADBA
en respuesta a: Anonymous
I guess you have restarted your workstation and tried again the recent file list handling?
Some info's that might help us:
  • which version of AutoCAD do you use
  • which service pack for AutoCAD do you use (command _ABOUT)
  • which operating system do you use
  • is Framework 4.7 installed in your system
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am wondering if this behaves correctly if you log on as a new user? I suspect a Reset Settings to Default might also correct this behavior.
John Vellek
en respuesta a: Alfred.NESWADBA
    • We are running AutoCad 2016  version 20.1.49.0
    • I will have to ask the user to get me this info as I am not on the system.
    • Windows 7 Pro
    • it look like .Net Framework 4.6.1 is install.  I will give the 4.7 a try.
thank you
Rob
Alfred.NESWADBA
STOP ... NO, do NOT install 4.7!
I just wanted to make sure that it is not installed!
That "49" means there are no service packs installed, please start with that.
- alfred -
Alfred NESWADBA
