10-07-2017
12:44 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-07-2017
12:44 PM
>> Some further googling has confirmed that it is impossible to change/move/reset the WCS
True, you can't modify the WCS.
If I'm understanding correct what you need you might try the following steps:
- Open your drawing
- Use command _UCS and set the rotation of the UCS in that way you want to have your (theoretical) WCS.
- That all layers and turn all layers on.
- Use command _COPYBASE with basepoint 0,0,0 and selecting all your objects in model-space
- Create a new drawing
- Use command _PASTECLIP again with point 0,0,0
...nowyour project is inserted in WCS like you have previously defined your UCS, save that drawing and try now to use this dwg-file with Revit.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
