10-07-2017
06:05 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-07-2017
06:05 AM
>> Autocad 2018
Which service pack? Start command _ABOUT and show as a screenshot from that dialog.
>> it crashes not only a particular file.
If it's specific to one file then run command _AUDIT or _RECOVER to find/repair errors in the drawing database (if there are any).
Or run command _WBLOCK with option "Entire drawing" ... then start with the new drawing created now and see if the issue is the same.
If nothing helps then you might upload the file so we can test it on our systems ... and please describe step-by-step what exactly need to be done to make AutoCAD crashing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
