john.vellek
en respuesta a: rkmcswain
Hi @rkmcswain,
I misunderstood your process but Kudos to you as this might work well for the OP.  I originally thought that once you had the datalink table in the drawing that you were then linking a field (perhaps in a block attribute) to a specific cell in the inserted table.  That process seems to only like numbers on my side because the link needs to be a formula.
I like your solution!
John Vellek
