dieters
en respuesta a: spaulus
Steve,
To add to the other recommendations, I'd suggest that it's super easy to use Save As and save a cleaned up, purged, drawing file as a drawing template (dwt) file. You just need to specify "AutoCAD Drawing Template (*.dwt) from the drop-down list.
The first time you specify it (on the Start tab, click Templates under Start Drawing), you can choose it as the default for when you next click Start Drawing. You can create several dwt files as starting points.
Hope this helps,
Dieter
Dieter Schlaepfer
Principal Learning Experience Designer
Autodesk, Inc.
San Rafael, California
