- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When I insert a field in my multi-text object that is being pulled from an attribute on my titleblock, the field is surrounded by a gray box. Is there anyway to change that so it appears as just regular text?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the grey background is just for the display, so you can see that this is a field value, it is not printed.
If you don't want that you can turn off FIELDDISPLAY (>>>details<<<)
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
@Alfred.NESWADBA's great answer is absolutely correct. The field background is displayed so that you know the text is not a piece of Mtext but that it is a field. It should not affect formatting or printing.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Perfect. I also learned that there is a command, UPDATEFIELD, that will update text on selected objects or depending on how the FIELDEVAL variable is set, running a REGEN command will update the all the MText that contains field data.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
Right you are. I hope that the feature proves useful to your work flow.
John Vellek
