- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Problems with Viewport Scaling
Hey gang,
I'm having a problem with my viewports when I'm changing their scale. I click on the desired viewport. I go to the quick select menu in the lower right, or properties and select the new scale. In the viewport, the scale changes, but the border of the viewport disappears. From here, I am unable to select the viewport itself. However, I can double-click into it to get to model space and everything in the viewport is visible.
This doesn't happen every time I change my scale though. It's seemingly random. I have found a poor work-around. If I change the scale and the viewport disappears, I can click undo to get it back. Also, if I click redo, the scale will change and the viewport will show up as it should. This is random as well. Sometimes when I undo/redo, the problem persists. If I try again, it will usually show up correctly.
Any ideas?
Andrew
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi and Welcome to AutoCAD Forum,
i suggest to check your layer 0 (zero) status that it's recommend to not be freezed. also try to attache your CAD dwg to share your issue .
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for your response. I never use the 0 layer and, as such, never need to freeze it. I should note that my viewports are on their own layer (.NoPlotViewportBorder) that is set up similarly to DEFPOINTS. I have attached my file here as well. Please note that it is in process and unfinished.
Andrew
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
would you please try the attached dwg file and see if any changes.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Seems to be fine now. What was the issue? <<
great ... all what i do is AUDIT and Purge (Regapps) your file.and reduce your units decimals. try it at your original dwg.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
