jwright1962
en respuesta a: rkmcswain
@rkmcswain wrote:
You can also use this with variables/arguments --- your menu macro could be (OpenLsp 1) to open your lisp folder, and (OpenLsp 2) to open the current drawing folder, etc.
I'll think on this...  This is a good tip and I'm sure I'll have opportunity to use this method.  I bet if time allows, I could "thin out" the number of utilities I have because lots of them have similar code...just copied from one lsp to another.   Providing a "switch" or "parameter" as you suggest would likely reduce replicating the similar code over and over again.  Thanks.
