- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
For years I've used StartApp to start "explorer" and open a folder where I keep my collection of lisp files. I've cut and pasted the same little code snippet out of the toolbar button from a prior version of Cadd I was using. Now, the durn thing only starts "explorer" in "Documents"... I pasted the same durn thing to the command line and it opens explorer in the root directory of the C drive... Whiskey Tango...?
This has worked for years...
^C^C(startapp "explorer" "C:/lsp")
but now... it does not.
any help out there? Thanks Forum!!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can also try this passing a number explorer command line parameters all in one shot:
(startapp "explorer.exe /n,/e,/select,c:\\lsp")
Area Object Link |
Attribute Modifier |
Dwg Setup |
Feet-Inch Calculator
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks to both previous replys. I've tried both but neither work. I've tried every combination I can think of with forward slash, back slash, no slash. but nothing seems to work.
(startapp "explorer" "c:\\lsp") This works on the command line only but not when pasting exactly the same in a toolbar button
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try defining a new lisp command function like OpenLsp and then enter this new command in the Toolbar ie:
(defun C:OpenLsp () (startapp "explorer" "c:\\Lsp"))
Then in the Toolbar enter:
^C^COpenLsp
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I know it sounds silly, but have you rebooted the PC?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
OK, I have it resolved.
I'm not sure what changed but I've tried every combination I could think of ... "to slash or not to slash". What worked was creating a separate lisp in my "lsp" folder; adding that lisp file as an autoload in acaddoc.lsp and then calling the function in the button as suggested above... OpenLsp this worked fine. I was hoping not to have to manage more lisp overhead to get it to work but it is what it is... and it works as suggested above. Actually; not a big deal to manage the lisp files. I have a "ton" of general "utility" lisp files I use quite frequently and it's nice to have a single click to bring up my lsp folder rather than clicking several times in Windows to get to that folder "outside" of cad.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Glad this worked out for you...cheers!!!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@rkmcswain wrote:You can also use this with variables/arguments --- your menu macro could be (OpenLsp 1) to open your lisp folder, and (OpenLsp 2) to open the current drawing folder, etc.
I'll think on this... This is a good tip and I'm sure I'll have opportunity to use this method. I bet if time allows, I could "thin out" the number of utilities I have because lots of them have similar code...just copied from one lsp to another. Providing a "switch" or "parameter" as you suggest would likely reduce replicating the similar code over and over again. Thanks.
