- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi there
I am hoping to find a solution on this issue I am experiencing. I have tried various suggestions in forums but none of those seem to be experiencing exactly the same issue.
I have attached two screenshots, both of the original dwg and how it looks plotted, you can see my problem!
What can I do to have the text and blocks printing accurately? It doesn't make a difference if I export or plot, and I have played around with various PDF options and settings. Some DWG files print better than others too I might add, so I am unsure if it is a default setting in the program or individually per document. My background is more so within Illustrator/InDesign and to my experience this looks like a missing link, but I'm not 100% sure if AutoCAD is set up in this same way.
Grateful for any advice!
¡Resuelto! Ir a solución.
