347 Vistas, 2 Respuestas
Plot to PDF
Hi there
I am hoping to find a solution on this issue I am experiencing. I have tried various suggestions in forums but none of those seem to be experiencing exactly the same issue.
I have attached two screenshots, both of the original dwg and how it looks plotted, you can see my problem!
What can I do to have the text and blocks printing accurately? It doesn't make a difference if I export or plot, and I have played around with various PDF options and settings. Some DWG files print better than others too I might add, so I am unsure if it is a default setting in the program or individually per document. My background is more so within Illustrator/InDesign and to my experience this looks like a missing link, but I'm not 100% sure if AutoCAD is set up in this same way.
Grateful for any advice!
Vinayv4v
en respuesta a: Anonymous
Turn of the plot object lineweights and use plot style.
And check if issue is resloved.
Cheers,
Vinay Vijayakumaran
en respuesta a: Vinayv4v
THANK YOU!! In the plot style table I don't have acad.ctb which seems strange BUT just turning off the plot object lineweights fixed my problem. You're a gem!
