leothebuilder
en respuesta a: Anonymous
The lines are simply too short for the assigned linetype to display.
If you stretch them you will find that they will display.
If you use imperial units I find that setting LTSCALE at 0.5 or 0.75 displays the linetypes better.
I appears that you have MSLTSCALE variable set at 1 and that should work well with setting and changing the annotation scales
