- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I was able to draw dashed lines earlier, but suddenly they appear solid regardless of the linetype I've selected. They also appear solid in the paper space.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I took a look at your file and noticed that your drawing had errors by using Audit. I copied the contents into a new file, set dimscale=1 and ltscale=1 and the dashed lines look fine now.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The lines are simply too short for the assigned linetype to display.
If you stretch them you will find that they will display.
If you use imperial units I find that setting LTSCALE at 0.5 or 0.75 displays the linetypes better.
I appears that you have MSLTSCALE variable set at 1 and that should work well with setting and changing the annotation scales
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
certain other line type options.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you use imperial units, make sure you use imperial linetypes.
Start with an imperial drawing template
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Don't mix the acad-iso linetypes with the others. If working in imperial then stay away from the acad iso ones.
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
