- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am using 2017 and 2018 Autocad and I am unable to even draw a rectagle over my viepwort and the system just crashes. Tried drawing the border around the viewport with pline command and when the curser moved into the viepwort it crashed.
Any help or suggestions will be appreciated.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please try:
- install the latest update(s) for your AutoCAD (2017 should be "Update 1.2" / 2018 should be "Update 1.1" currently)
- disable hardware acceleration (command _GRAPHICSCONFIG)
- use a new drawing based on an original AutoCAD template
If nothing helps please create a screencast (>>>free Autodesk Screencast<<<) and show us your steps so we can try to recreate them using the same steps.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
does this issue happened in every CAD file ? if NO .... please attache your CAD dwg that behave like this .
regards,
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I feel that @Alfred.NESWADBA and @imadHabash have given you some great starting points.
- Verify that your product is fully updated
- Disable hardware acceleration
- Use a clean (original) template
- Verify that the drawing is not the problem by running AUDIT or RECOVER
If these steps do not resolve the crashes please post back. When your AutoCAD crashes, do you have any kind of error message or do you have the opportunity to submit a CER Report? If you do have a report please capture the case number so I can look up the error for you.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for all the replies.
I updated to 18.1 and the issues were resolved. I finsihed three more drawings today without any problems!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
