09-30-2017
01:05 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-30-2017
01:05 AM
>> I am running Carlson on AutoCAD 2016 (Carlson Support tells me it is an AutoCAD
>> issue...But i have friends who are Carlson users that are having similar issues.)
Sorry that I don't help to solve the problem, but I can only confirm that I have not seen that and have not read about that ever before for plain AutoCAD.
So I guess your feeling about the add-on could be the right direction.
Do you use the AutoCAD dimension or do you start a Carlson dimension command?
What happens, when you start the AutoCAD dimension commands with underline + a point at the beginning of the command, e.g.
_.DIM or _.DIMLINEAR ...
does that also change the assigned font?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
