john.vellek
en respuesta a: Anonymous
HI @Anonymous,
Just to clarify, is your Windows 10 64-bit? If so, then make sure you have grabbed the correct version of AutoCAD (64 bit). If you are trying to install the 32 bit version it will give such an error message.
If all versions are correct then I would personally create a Bootcamp partition and install there. If you are still getting errors there then something else is going on.  If it does work in Bootcamp then Parallels should be able to convert the Bootcamp partition.
John Vellek
