Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
.... I want to set my UCS to a Floor Level 1 height of 60' & I need to install the conduit to a height of 12'.  ....
I don't quite understand, either....  Does that mean you want the conduit at 12' above that 60' floor level, or 12' relative to 0', that is, 48' below  that floor level?  When in the 60'-floor-level UCS, what are you doing exactly to install it at 12' [as @pendean asked]?
Depending on what you are really after, you may be able to get it by using the ELEVATION System Variable rather than [or in conjunction with] UCS.
Kent Cooper, AIA
