beyoungjr
en respuesta a: Anonymous
Two options for you...
1. Type UCS and enter the new origin that you need (eg. 0,0,60').
or
2. Use the 3-point UCS icon command on the Home ribbon of the 3D Modeling workspace.  You will be prompted for a new origin point.
Both of these options will allow you to create a new UCS that is set at 60' so that when you draw something 12' in height it will be at 72' in the WCS height.
If your new UCS/s are important to you then consider saving them in the Named UCS dialog box.  You access this via the +UCSMAN command or use the corner arrow on the Coordinates panel of the Home ribbon.
Is this what you were looking for?
Blaine Young
Senior Engineering Technician, US Army
