09-25-2017
09:41 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-25-2017
09:41 AM
HI @Anonymous,
Thanks for the extra detail but I do understand the issue you are describing. I have however, never seen this issue and I can find no other cases that sound similar.
I wonder if if the image that gets deployed has an error in it that is preventing this from working correctly.
Are you adding the network share to just the Support File Search Path? Or, are you adding it to the Working Support File Search Path and Trusted Locations as well?
If you add the path and then save the workspace are you then able to see if all the paths are retained?
John Vellek
