en respuesta a: Anonymous
maybe I'm not describing it right or a visualization will help, see images attached
I logged in with a local account (no network drives) you can see the Network drive listed in the support file paths, but since it is not loading all the default paths are as well, which can also be seen in the "working paths"
I then mapped the network drive manually and re-opened autocad, the result most of the default paths disappear
Manually re-adding does not help, the instructors have found a few things this alters
I have checked the permissions on the share, and it is "full control" as it should even though I would think the permissions on their should not affect the local files. remove the network drive completely and every thing besides the custom tool bar that is stored on the network drive operates perfectly.
I am currently in the process of creating a spot on the C: drive for the custom toolbar but I suspect this should work fine as this is how the instructors have it set up on their laptops (problem being on the Teacher stations in the computer labs)
Being educational our license also does not permit us support from autodesk outside of this very forum
If anyone has seen this or has any ideas as to actions I can take it is appreciated!
