john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I like this idea but I am not aware of a routine to do this automatically. Obviously, most Document Management systems will create versioning but I am not sure if one is in play here.
When  a file is saved in AutoCAD, a BAK file is created and not another DWG. In the past, I have required users to keep the active drawing to retain the original name. Older versions should be moved to an appropriate version folder and possibly also renamed (perhaps with the date last published in the name).
Let's see if anyone here in the Community has another automatic solution for you.
John Vellek
