- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD 2017 very slow print preview & print
This particular user has an issue with very slow print preview / printing. Doesn't matter what size the drawing is. We tried a couple different ones. If he clicks to plot, chooses to hide the legacy, and then clicks on preview - it takes almost 3 minutes for the preview to come up. We timed it!
6 month old computer. New install of AutoCAD 2017
Xeon 2 core 3.5Ghz
Windows 10
64GB ram
Nvidia Quadro M5000 video card
I have tried the exact same drawing on an older computer, also using AutoCAD 2017 - same process and it takes about 25 seconds.
What we have tried:
- using the older version of DirectX
- updating the video card drivers
- running all the autoCAD patches
- making sure all windows updates are run
- turned off video acceleration
- made sure only one video card was enabled in Device Manager
- Emptied the temp folder
Anything else I should look for / try / change?
Note: we have approximately 30 people with similar setups and he is the only one having this particular issue. The Win7 computers seem to work better for some reason. maybe its a Windows10 setting somewhere???
Thanks in advance!!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Which plotter driver?
It might be the plotter driver on the other system works better?
Which operating systems do these 2 computers have installed?
What happens if the plotter is set to use "DWG to PDF.pc3", and then do a print peview?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Plotter driver is the HP Designjet T770 HPGL2 - downloaded/installed from Windows Update
The slow machine has Windows10, the faster one has Windows7
I cant try the DWG to PDF option at the moment. But that wont really help him because he needs to plot the drawing. But I will say, when he prints to his little ink jet printer its much faster, but still takes longer than on the Win7 machine.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please avoid using drivers from a Windows update (as long as others are available), either use the HP driver for that plotter or the HP universal driver >>>like that<<<.
But it would help to isolate the problem!
Currently we don't know if the reason is the workstation, the operating system, the plotter/driver or the AutoCAD profile.
If "DWG to PDF.pc3" creates a faster result then we can concentrate on the plotter/driver (as it's not AutoCAD and not the operating system).
- alfred -
Alfred NESWADBA
