1737 Vistas, 9 Respuestas
Support file paths disappearing
Hello all
so this year we moved some files/folders to network drives, allowing the instructor to modify the files and maintain them with out needed to request assistance from IT like when it is on the local drive (our local drives have a program called deep freeze that makes it so changes on here wont stick)
 problem being when I add the network drive path into the support file paths, I'm loosing 6 of the default paths removing a lot of content that is required for the instructors. If i remove said network path, the default ones repopulate.
I have changed the order the paths load in, and manually re-added the paths, but as soon as autocad loads the network path, the other paths are gone
Any Ideas?
