21089 Vistas, 7 Respuestas
How to do a cutline
I have a wall that continues but I don't want to show the complete wall so I would like to use cutline but don't know how to. Can some help !
en respuesta a: Anonymous
You can use the "breakline" command.  The size of the breakline is control by the dimscale factor.
Alfred.NESWADBA
not sure to understand the question correctly. You have  long wall which does not fit to a plot-format, so you want to plot the start of the wall and the end of the wall, but not the complete length on the plot .... if so, then create two viewports, each showing one end of the wall.
If I'm wrong, then please describe your question a bit more detailed, maybe with a drawing that shows your situation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I made a quick video to show Alfred's great suggestion. To take it further, you could use the breakline as described by @Anonymous to show that it is broken.
John Vellek
imadHabash
use Breakline command and try to get this result.
Imad Habash
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
aadish_rahman
thank you :cara_con_una_leve_sonrisa:
aadish_rahman
en respuesta a: john.vellek
ty :cara_con_una_leve_sonrisa:
