09-19-2017
12:41 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-19-2017
12:41 PM
blyoung wrote:
BTW... You will only get index colors from the Properties Manager.
Elaborating on @beyoungjr's post above, the actual True Color you set the text to in the dimension style hasn't changed--it should still be the true color that you assigned (you can check this by double-clicking the text of the dimension and see what color is shown in the text editor), and it should still print with the true color when using the monochrome ctb (you can check that in the print preview). It's just a quirk/flaw/bug in the properties palette that it "rounds" to the nearest index color when showing the properties for the dimension.
Stefanie
crazy autocad witch since release 8
