8668 Vistas, 2 Respuestas
Can Surface Pro 3 run Autocad and Revit?
I know this is just for AutoCAD but I need to know about Revit as well.
Someone is offering to sell to me a Surface Pro 3 with:
512 gb storage
8gb of ram
64-bit system
i7-465OU
CPU @ 1.7GH 2.30 GHz
Will AutoCAD and Revit run on this?
What are the pros and cons?
I realize that rendering probably won't be great but that's fine with me.
DarrenP
en respuesta a: Anonymous
there have been multiple threads on this already
here is one here: https://forums.autodesk.com/t5/autocad-architecture-forum/can-the-surface-pro-3-run-architecture-sof...
 more here: https://forums.autodesk.com/t5/forums/searchpage/tab/message/page/2?advanced=false&allow_punctuation...
you will have to determine if its worth getting based off the information from other people on this forum
DarrenP
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I know that there have been some issues with the graphics card and getting hardware acceleration to work in AutoCAD on the Surface Pros.  If Hardware Acceleration is not critical then the other specs are fine.
John Vellek
