3022 Vistas, 12 Respuestas
Fatal Error AUTOCAD 2015
Hi There,
I have some problem with my AUTOCAD 2015. Suddenly some error apear when i try to open AUTOCAD
Can someone help me with my problem?
imadHabash
en respuesta a: Anonymous
there are many reasons that cause such a problem. i suggest to read and follow here these solutions that it may help. >> Click <<
Imad Habash
en respuesta a: imadHabash
Hi Imad,
Referring to your links, and i found like this :
Solution:
There are several ways to troubleshoot the problem:
I have already update all software requirment via Autodesk Application Manager, but all the issue seems not solved.
Already opening any file .dwg. But the error keep showing
  • Uninstall any antivirus or desktop locking programs.
    These programs can cause errors in AutoCAD, since they prevent the system environment from working.
No single antivirus installed on this PC, i already uninstall it
Done Resetting, but still error
My PC use the lastest driver
Already try that too, but no effect at all. Still error
  • If DisplayLink Core software is installed on your system, try uninstalling it.
No DisplayLink Core software installed
Already try this too, but error still appear
  • Clear the digital signature icons and then uninstall and reinstall the application.
            See:   FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h
  • Configure Internet Explorer as the default browser and remove all check marks from the LAN Setting option.​
  1. Open Internet Explorer.
  2. Click Tools > Options.
  3. Access the "Connections" Tab.
  4. Click "Lan Settings."
  5. The settings should look like this:
Lan Settings
imadHabash
if you launch autocad from a new user account ... any changes ? or / and launch it as admin (Run as Administrator ).
Imad Habash
No affect at all, the error still same. Just now i figure it out some update avaible in Autodesk Manager. I download it, and then the error code change like this :
But after i click OK button, AutoCAD will suddently closed, just like previous error code
Alexander.Rivilis
Try to disable Windows Firewall. Similar problem was solved: https://forums.autodesk.com/t5/autocad-forum/fatal-error-unhandled-error-c0000006h-in-autocad-2017/t...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Alfred.NESWADBA
what happens when you disconnect your workstation from network and then start AutoCAD?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
en respuesta a: Alexander.Rivilis
Done, but still no effect. Same Error Code still appear
en respuesta a: Alfred.NESWADBA
Hi Alfred,
The error message still appear, but the code seem changes
en respuesta a: pendean
Hi @pendean,
I follow your instruction, but my OS not avaible on there. I using Win 8 Pro
ennujozlagam
@Anonymous hello, try to repair or reinstall program it could be some files are corrupted. thanks
Alfred.NESWADBA
does your system have Framework 4.7 installed? If so uninstall it and install version 4.5 or 4.6.2 instead.
- alfred -
Alfred NESWADBA
