en respuesta a: TheCADnoob
Thanks for your ripple.
But it did not help.
My 'eps' file was created using 'pc3'.
PostScript Level 1
PostScript Level 1 Plus
PostScript Level 2
Even if you create an eps file using the same symptom is not solved.
The use of crosshatch hatches is a very inefficient way of working with large scale drawings and is also a problem when loaded by the 'Place' function in Photoshop.
