pendean
en respuesta a: Anonymous
>>>...Only once so far....<<<
That's not worth posting for or talk about buying a new laptop (or desktop): when you can repeat the crashes at will in ALL files with the same command, then it's a problem to discuss in these forums. Are you able to do so? Please test and find out.
What is the make/model of the laptop were this crash happened only once so far?
FWIW My personal 'upgraded' suggestions for 90% of users out there (you can always add more if you feel you can justify it):
- Desktop: i7-7700 clocked up to 4.2Ghz, 32GB (minimum), 512GB SSD (minimum), GTX1080 4GB or Quadro M2000 4GB (minimum)
- Laptop: i7-6820HQ, 16GB (minimum), 512GB SSD (minimum), Quadro M2000M 2GB or FirePro W5170M 2GB (minimum)
