en respuesta a: john.vellek
Wow thank you!!!
That was verry helpful indeed!
I successfully did that and polar arrayed 10 petals around center`s extruded circle :cara_con_una_leve_sonrisa: The only problem is I cannot do the same with the center circle (dome)
As You showed in video, two sides must be in polylines... I tired to simulate the same with center dome, by creating two arcs and spline... Lofting still wont work... what am I doing wrong.... All the videos of creating dome on Youtube are not very helpful because they either demonstrate it in old autocad or the video is without comments... x(((
