en respuesta a: Anonymous
The most radical solution is restore dwg files of autocad 2002 when other methods don't work
The place where you may read various thing about Autocad - http://www.thesourcecad.com/recover-damaged-or-lost-autocad-files/
Here you may read more about article below: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Drawin...
However, a few things may get it to open:
  • Try to open the drawing file directly instead of using the Recent Documents menu.
  • Check that the storage location that holds the drawing is working properly.
  • Use the RECOVER and RECOVERALL commands on the drawing.
  • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
